Visualization
SOLVED!
Color zones
I find the zone tool of archicad very useful. I want to use it for skins and scheme at the first stages of a project or for presentations in a conquest panel. I like to use them in 3d as well in 2d. Is there a way I can use the colours of the 3d zone model, in 2d. Because the only option I ve got is using the surface color for 3d and the fill in colours for the 2d. I like to have the same color for both.
Regards
1 ACCEPTED SOLUTION
Solution
Link
I just set Zone Category color and the Zone Surface to be exactly the same color then you can see them in 2D and 3D.
Link.
5 REPLIES 5
felcunha
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Solution
Link
Link.
felcunha
You mean having to do twice the same job... for a few zone categories it's ok but it can be painful if we deal with several ones...
Link
I have 44. Just set it up once in your template and you'll always have it!
Link.
jc4d
Would be so much easier to have an extra option under MODEL that reads: Take color from Zone Category.
