Columns Showing on Non-Relevant Stories
Guru
Hi all,
I have a set of columns which are showing below the story they are on when set to show on "All Relevant Stories". Two stories below in the carpark is definitely not relevant...
Setting my FPCP to not show any above stories does not make any difference...
Ling.
Guru
Ah... That was obvious... The inverse of the issue I had with the stairs on the zero height story... Solved for now with a negative top Floor Plan Range.
Ling.
What are the heights for the 2 storeys below ground floor?
I assume GF is at project zero.
Your columns are 100mm below project zero, so they will definitely show one storey down.
Guru
Ling.
