Short answer - no.
Long answer - you can select the 2 windows and save then together as one window object.
But you will lose all the window parameters so your schedule will probably not show the information you want.
It would be a lot of work to add the parameters back in to make the windows like the others.
Also if saving 2 windows as one new window object it also seems to save the wall as well so make the wall as small a possible or convert the windows to Morphs and save the morphs only as the new window.
Basically you need to create a custom window but as I said you won't have all the parameters to make it adjustable and you may not have all the information you want for your schedule.
What type of window are you trying to create that requires two separate windows?
