Command Line or Revit Style Shortcuts
Hi everyone!
I've been working exclusively in ArchiCAD 20/21 for about a year now after moving from Revit & AutoCAD. While I've been able to adapt to most of the differences, one thing that I really, really miss is the Revit keyboard shortcuts. Specifically, I'm referring to the 2-key shortcuts...(typing "wa" starts the wall tool). Is there any way to enable that functionality?
Additionally, I keep hearing whispers about there being a secret AutoCAD-style command line in ArchiCAD. If this is true, how in the world do I enable it in AC21?
Thanks so much!
4 Replies 4
mikas
That would be nice to be able to configure double character shortcuts too.
You probably have found out how to make your own shortcuts for tools too?
If not, the tools reside in the menus too, so you can make a shortcut to any of them. Maybe something like Shift-W = wall tool. You just have to make sure to not make overlapping shorts, of course.
Options-Work environment-Shortcut schemes
(see pic)
AC28, Rhino8+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
I have figured that out, yes. Personally, I don't like using the modifier (CMD/Shift/Option) keys because I find it faster to use 2 characters ("wa").
(see pic)
Eduardo Rolon
My shortcut for Wall is "w" so I think that it is faster than "wa" but seriously my concept for shortcuts are:
Main Tools = single letter
Editing Tools = CMD and Letter (CMD+C = Copy therefore CMD+I = Intersect)
Function Keys = Main Toolbars
CMD+Numbers (1-5) = Main Palettes (Navigator, Organizer, etc)
CMD+SHIFT+Numbers (1-5) = Secondary Palettes (Trace Reference, Renovations)
etc,
Most reachable with my left hand with some exceptions. But I wouldn't mind having extra options for shortcuts.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
You can map modifiers to your mouse so that everything is essentially 1 character.
Richard
AC26 (since AC6.0), Win10
