Commode Step: The bottom step of a flight of steps.
Commode Step: The bottom step of a flight of steps, the end of the step being curved.
Is there a way to use ArchiStair 1.0 to model a set of stairs that start (end) with a commode step. ArchiStair can model a step that is curved across it's entire width but is ther a way to get it to model a step as shown in the image below?
Is there an alternate way to model a stair with a step that is curved or rounded on one side?
Thank you,
John
6 REPLIES 6
I'm not sure about ArchiStair, but I'm pretty sure Niel McCann's D3 SmartParts library has objects (subassemblies) that can be assembled to create that stair. It's not as convenient as the single element of ArchiStair but it sure beats building the stair out of bits and pieces (as I have done on occasion).
Have a look at the ArchiStair manual, page 56 - Custom Stairs.
I'm about to give it a go...
Gave it a go, it works pretty well.
Here's some fills drawn to the shape of my stair:
And here's the stair that Archistair created.
Stress Co_
If all else fails.....Model the first step as a slab.... then, start the stair from the slab?
Marc Corney, Architect
Red Canoe Architecture, P. A.
Tom wrote:
Have a look at the ArchiStair manual, page 56 - Custom Stairs. ....
Hi Tom, are you viewing the Manual from a PDF or do you have a Bound "real" copy of the Manual?
I am looking to get a hold of a printed Bound manual.
Jay wrote:
...are you viewing the Manual from a PDF or do you have a Bound "real" copy of the Manual?
Just the PDF I'm afraid. A hardcopy would be nice though...
