‎2007-03-06
08:09 PM
‎2025-07-22
12:22 PM
Aruzhan Ilaikova
‎2007-03-07 05:04 AM
‎2007-03-07 05:23 AM
‎2007-03-07 05:49 PM
‎2007-03-07 07:47 PM
Philip wrote:I'm not sure what it is it only seems to do it with that wall. I made another one in a different file and it came out right. Then I copied it to the original file and it worked there. And I made a new one in that plan it also worked. Must be something I did in the first wall. They should be intersecting exactly I used the rectangular geometry.
I tried to replicate your problem and it worked perfectly regardless of where I placed the origin. Did you check that the two elements are intersecting exactly?
BTW I also find it more useful to place the foundation separately but it's a matter of choice.
‎2007-03-07 07:56 PM
Steve wrote:
By the way... I see that you have an M90. Very good machine I bet.
I have been using an M60 for several years now as my main work station. I hope you got the WUXGA LCD. 17" right?
I have a Dell 650 Precision Workstaion also but this little bugger does just fine and I can take it with me anywhere.
I have it hooked to a Dell 24 inch UltraSharpâ„¢ 2407FP Widescreen but it looks like crap compared to my laptop. I keep ArchiCAD on the big screen and my e-mail and other programs on the laptop screen.
‎2007-03-07 11:15 PM
‎2007-03-08 01:16 AM
Link wrote:
It sounds to me like you may have missed the mark with the local origin in the profile editor. This is according to Graphisoft literature:
The generation of the Profile happens according to the following rules:
In case of Walls: if you are looking at Wall from its starting point toward its endpoint, and if you created the Wall using the Left Construction Method (i.e. the body of the Wall extends to the left side of the Reference Line) then the placed Profile wall will face the same direction as shown in the Custom Profile Editor. If you switch the wall’s Reference Line to the other side, or if you view it from its endpoint toward its starting point, you will see the vertically mirrored image of the Profile. The Local Origin of the Custom Profile will placed at the Wall insertion level (base height) as defined in the Wall Settings dialog.
It would probably be best to upload a module of these walls for closer inspection.
Link.
‎2007-03-08 02:12 AM
‎2007-03-08 05:25 PM
