Complex Profiled Walls
Good Morning
i am running Archicad 16 Can someone please explain how i can place several materials On one Complex wall profile
Thanks
Mark
4 REPLIES 4
You do it by editing the profile itself. Mouse down on the edge for which you want to change the extruded material - and select from the pet palette to change the properties of that edge. See Help for editing Profiles.
One of the forum moderators
AC 28 USA and earlier   •   macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks Karl, I have been reviewing the editing profiles and i feel i am missing something, when i edit the material on the skin the entire profile changes. Under archicad Help It shows a editing Tool bar and a Custom Edge Settings Box, I am getting neither one of those items, I know it must be a setting but i cant seem to locate it, any suggestions?
Dwight
Working in the Complex Profile Editing window, of course.
Dwight Atkinson
Thanks Karl
I found some of your earlier post and realized I cut and pasted my complex wall into the profile manager and that does not work. Once i imported it correctly. It worked great
