ā2007-06-13 09:20 PM
ā2007-06-13 09:37 PM
ā2007-06-13 09:42 PM
ā2007-06-13 09:43 PM
TomWaltz wrote:If so then Complex Profiles is the winner...
Composite walls redraw faster. Not a big deal on a small project but can REALLY drag down on a 50,000 SF footprint....
ā2007-06-13 09:55 PM
Scott wrote:
........, complex profile changes do change the wall height.
ā2007-06-13 10:11 PM
Joseph wrote:by default, you cannot set the heights of a profiled wall, but you can add a "stretch zone" so that you can make them taller or shorter.Scott wrote:
Could you explain this a little more?
Thanks,
Joseph
ā2007-06-13 10:15 PM
ā2007-06-13 10:18 PM
TomWaltz wrote:but sadly if you are changing profiles, even betweens profiles with a stretch zones, they don't stretch to match the height of the existing wall, they changes to the default height stored in the profile manager. so suddenly my 8' wall is now a 15" wall, that I have to change back to 8'Joseph wrote:by default, you cannot set the heights of a profiled wall, but you can add a "stretch zone" so that you can make them taller or shorter.Scott wrote:
Thanks,
Joseph
ā2007-06-13 11:00 PM
Scott wrote:I'm pretty sure they fixed this with one of the last 2 hotfixes -- what build are you on?
but sadly if you are changing profiles, even betweens profiles with a stretch zones, they don't stretch to match the height of the existing wall, they changes to the default height stored in the profile manager. so suddenly my 8' wall is not a 15" wall, that I have to change back to 8'
ā2007-06-13 11:33 PM
