Complex Profiles and Window
Attached is a PDF of what my windows are doing in Plan and a PDF of the Complex Profile I used.
In the profile the blue lines are the Opening Reference lines.
Can anyone tell me why the window insists on sitting so far into the wall as it is?
Thank you
7 Replies 7
here is the second attachment
Hi Jess,
Have you tried to modify the "Construction Method" along with the "Reveal Depth" value?
Cheers.
Adrian Tudoreanu
adytc- Yes I have , too many times and ways. Thank You for the suggestion.
Link
What is your window's floor plan display set to? And have you tried any of the others?
Link.
"Can anyone tell me why the window insists on sitting so far into the wall as it is?"
Try the wall types in the parameters of the window itself.
I had a problem like yours and that fixed it.
Once you have picked right wall type for your complex profile wall there also might be one other setting, but can't remember right now.
Yes I have tried the other floor plan settings for the windows. Even if I can change it to look al ittle better in plan it still shows weird in section.
I have also tried the different wall type settings.
David Maudlin
Jess:
Your problem might be related to this thread:
Openings in complex walls
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
