ajharlan
Complex wall profile intersections
Has anyone experienced this interaction between two identical complex wall assemblies?  I have tried adjusting intersection priorities, but the bottom of the wall assembly (where sheathing, mineral wool, and stone overlap the foundation) seems to not respond to those priorities?
Help?!?
1 Solution
Lingwisyer
Guru
This has popped up a few times... There are posts about it around here somewhere... Put your footing in a different Intersection Group. The issue is that they are trying to connect to your footing. Playing around with the Junction Order of your 4 walls at each instance can sometimes work.
https://community.graphisoft.com/t5/Modeling/Wall-quot-wings-quot/m-p/293426
Go to post
2 Replies 2
Lingwisyer
Guru
ajharlan
@Lingwisyer this worked like a charm, thank you!!
