Complex wall profile?
I would like to draw a wall that is 330mm thick, 700mm high, made up out of a double skin of brick and the cavity filled with concrete. I made one up in composite materials but I want the outside skin to be one brick, ie 90mm, higher than the inside skin and the concrete cavity. This is especially important in cut sections.
Thanks
1 Reply 1
If you're using AC10 you can do this with Complex Profiles (design menu). Have a look thru the Help files for more info.
