Composites resolving conflicting priority requirements
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2016-07-11
03:04 AM
ā2023-05-24
08:38 AM
Rubia Torres
ā2016-07-11
03:04 AM
In my current situation, concrete needs to master insulation for internal corners, but be mastered by insulation on certain external corners.
In section, concrete also needs to master insulation.
A nasty workaround seems to be to add a 0.01mm skin of concrete to one wall, but this surely is not the BIM way?
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-28 | Twinmotion 2024
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2016-07-11 04:01 AM
ā2016-07-11
04:01 AM
You will probably need to duplicate your building materials so you can have a stronger and weaker version of each.
Then possibly even duplicate your composites so you can use the various strength building materials in them.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2016-07-11 04:48 AM
ā2016-07-11
04:48 AM
Barry wrote:Thanks Barry
Unfortunately different materials definitions seems to generates extra joint lines in plan and/or elevation & section where two variations of same wall abut each other. I also have the case where the same wall needs a material to dominate in plan and recede in section - so could end up with a mosaic of abutting wall segments to seal with each scenario.
I would love GS to proveide for one off local materials priority overrides associated with specific junctions and views
