Conditional formatting zones - Graphic Overrides
Johan Stinckens
I'm baffled!
I thought it was possible to have a Graphic Override apply condtional formatting to a zone. But apparently it isn't.
I am working on a client-specific template which we want to use for their future projects. Since they utilize a specific set of standards I would like to create zone categories for each of the rooms/functions within the building. That way I can create a specific override for each of them, by which I will have a visual warning whenever any of the rooms doesn't meet its standard. I hoped to set this up using GO, but can't seem to find the variable with which to do this.
Since "The Dawn of Graphic Overrides" I have been an avid user of it. But this is a real bummer?!
Has anyone found a way to bypass this?!
Any help would be greatly appreciated.
Johan Stinckens
BIM Modeller at Atrium Architecten
Archicad user since April 2014 (v17 - v27) - CC iRT i9-12900 - 64 GB / Nvidia Geforce RTX 3080 - Windows 10 Pro 64
Other than that it's hiking, camping, climbing.
5 REPLIES 5
Erwin Edel
You can override zone fill and such, but you may already have some general zone override in place messing up the settings. You might have to play a bit with the order of the override rules.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Johan Stinckens
Erwin,
I might not have expressed myself clearly here.
What I would like to set up is a set of rules that whenever a specific zone's area is beneath a set threshold, the Graphic Override automatically changes its color. Suppose the stock area in a building needs to be 300m² and the shop area needs to be at least 1000m². I would like to set up a GO combination to change the display of the zones accordingly. So whenever during design/drafting I would change the shape/contour/size of a zone, the GO checks if I haven't made it smaller than needed.
For zones in Category "Stock area" it will test if the net area is at least 300m² -> True -> Zone Fill = Transparent / Text Color = Black -> False (less than 300m²) Zone Fill = 50% red / Text Color = Red
For zones in Category "Shop area" it will test if the net area is at least 1000m² -> True -> Zone Fill = Transparent / Text Color = Black -> False (less than 1000m²) Zone Fill = 50% red / Text Color = Red
Hope this clarifies what I am after.
Johan Stinckens
Erwin Edel
You won't be able to that directly, however, with properties you would be able to do it.
If you create a custom property for these things, you can use that to drive the GO rule.
To flag the properties, you could either do it manually using a schedule or export that schedule to excel, set up a rule set there and import the excel back.
A different approach would be to code a zone stamp (or modify the one you are using) and just flag a parameter there to show something on the zone stamp (i.e. "voldoet/voldoet niet").
www.leloup.nl
Erwin Edel
https://helpcenter.graphisoft.com/guides/archicad-20/archicad-20-reference-guide/interoperability/ar...
Here is the workflow for import / export of property data using excel.
www.leloup.nl
runxel
Hero
A massive overlook, if you'd ask me!
We can check for the heights of rooms, but not their size?! How ridiculous!
