Connecting Complex Beam to Slab
Jackcowdrey
Hi all,
I am modelling an existing ribbed slab and was wondering what is the best way to connect the complex beam profiles of the T's to the slab, as they intersect at an angle.
Thanks!
Ahmed_K
yes , it must connect, create a thin beam, just to force your beams to connect
Archicad 27
Windows 11 professional
10 REPLIES 10
Ahmed_K
 Add a beam on the slab egde, beams connect only to beam
Archicad 27
Thank you for your reply. Does the beam have to connect to the same complex profile beam?
Ahmed_K
Archicad 27
@Jackcowdrey,
Which Archicad version are you using? Archicad 23 introduced multi-segment Columns and Beam using which you should be able to model those Beam ends.
Hi, thanks for your reply.
Sadly we are using Archicad 22.
Hmooslechner
Maybe, it would help, if You send us a handrawn Picture of Your wish here..
Jackcowdrey
Hi Hmooslechner,
I have attached a screenshot from the model.
I see - sorry!
correct me, but the beams in the slab "in real live" should carry the slab - and should reach ( lay on ) the surrounding wall-forms, so they shouldnt connect to the slab but "lay on the wall" instead?
What you could do in every such situation - not using beams but unsing morphs, which you could easily cut off at any angle
Jackcowdrey
Hi again,
I have modelled them as 'beams' however they are the ribbed parts of the slab, and therefore need to be connected to the slab. Please see attached.
