Connecting beams on angles
Gidday fellas
I was just wondering if there was a solution to my problem...basically I have 2 beams joining together but they are not at 90 degrees to eachother...is there a way to adjust a section of the column so it fits snug? ***LOOK AT PICTURE*** I hope it works!
Nuggy
11 Replies 11
They can sort it out later!!!! Its only for a uni assignment...my lecturer probably doesn't even know the difference between an apple and a banana...................one's hard and the other is soft!!!!
Djordje
Don't count on it ...
ArchiCAD is very good in making you think how the design will be built; IMHE, we have to think about the structure while designing, in order not to be taken for fluffybrains that only think in shapes and colors.
If they do "sort it out later", you would not want anybody to know that the design is yours, trust me 😉
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
