2023-05-16 12:51 PM - last edited on 2023-05-17 12:24 AM by Gordana Radonic
Hi there. I have a trouble with connecting the sloped beam to the horizontal one. This is how it looks like:
I've always had this type of trouble. I get the point that one profile is sloped and the second one is horizontal, so they can't match exactly. Bu what you do in this type of cases?
Solved! Go to Solution.
2023-05-17 12:31 AM
Put a 90 degree flat return on the top beam and connect the sloping beam to it.
2023-05-17 10:46 AM
Yes.
You always need to turn the corner on the same plane, otherwise it is impossible to mitre the profiles (properly).
The builders will have exactly the same problem on site.
I am not sure what the technical term is, but I call it a transition zone.
Here is a post I made some time ago using a profile in the railing tool.
It shows the transition of the profile around the corner.
2023-05-17 12:17 AM
Hi @Kikoria,
Are you using complex profiles with the beams in the example?
Regards,
Gordana Radonić
Community Manager
2023-05-17 12:31 AM
2023-05-17 10:23 AM
Yes, I am. But this case happens in simple profiles too.
2023-05-17 10:24 AM
Do you mean something like that?
2023-05-17 10:46 AM
Yes.
