2004-09-10 08:53 AM
2004-09-10 11:53 AM
Maurice wrote:I think if it happens once is not a problem, you might have incorrectly drawn a slab or a fill or a roof or something.
Has anyone had a "consistency error" dialog box with "1 or more elements have been deleted"?
Does anyone know if the file is too corrupt to continue using even if the 1 or elements where deleted.
I just started getting this error when using the detail tool and the interior elevation tool
Any hints/ comments would be appreciated.
2004-09-11 09:49 PM
2004-09-12 04:36 AM
2004-09-12 10:33 AM
2004-09-13 01:59 AM
2004-09-13 11:49 AM
ejrolon wrote:Thanks to all for your replies. I am continuing to work with the file. It appears the error occurs when saving after using the interior elevation tool.
Try this option
http://archicad-talk.graphisoft.com/viewtopic.php?p=20704#20704
I just found this work around today
2004-09-13 02:55 PM
2004-09-13 05:49 PM
Maurice wrote:This has happened to me only with the section/elevation tool, and only when unlinking. I am asked "delete dimensions or change to static". I choose "change to static", then the dimension seems to be deleted anyway. When saving later on, I get that message. The number of deleted items always corresponds to the number of dimension strings I have lost. Or so it seems. I click "save anyway" and everything has been ok.
Has anyone had a consistency error dialog box with 1 or more elements have been deleted
2004-09-14 10:31 AM
Stephen wrote:Steve, next time try selecting all linear dimensions and turning them to static manually. This way you will surely not lose them when unlinking the S/E.Maurice wrote:This has happened to me only with the section/elevation tool, and only when unlinking. I am asked "delete dimensions or change to static". I choose "change to static", then the dimension seems to be deleted anyway. When saving later on, I get that message. The number of deleted items always corresponds to the number of dimension strings I have lost. Or so it seems. I click "save anyway" and everything has been ok.
Steve
