Constant hotlink module relinking, every time I open a file :?:
Every-time I open Archicad my hotlinks are broken and I have to go into the hotlink module manager and "update" them. I shouldn't have to do this and haven't had to do this in the past. See link for video repro.
https://www.loom.com/share/9b9a772623a74656a2ba7c74d95fabdb
4 Replies 4
Guru
Bit dramatic there... Not broken, just requiring an update.
So, if you update the hotlink, save the file then close and reopen it, do you still get the update query?
Ling.
@ling It's not dramatic. Are you hearing what I'm saying??? EVERY TIME!!!! Not, once, not after I update and save, EVERY TIME I OPEN MY FILE!!!
I see from your video that the hotlink is set to 'Check Manually'.
Have a look in your Work Environment and see if this setting helps.
@Barry thanks! It was not checked. I'll see if that resolves it. Weird that it just started happening though.
