Constructing a 'screen'
I'm having a bit of difficulty in working something out. Basically, I have a facade that extrudes from the main building fabric to form a screen. What I can't work out is how to make this 'wall screen'
I've attached a sketch to show what I mean. Any tips on how to achieve this is much welcomed.
Thanks.
undefined
7 REPLIES 7
Use a wall with a couple of empty openings.
Rod Jurich
Or, 4 walls, or 3 walls, 1 beam, or 3 columns 1 beam.
Or a combination of all 3 elements. How it represents in 2D
will influence your decision. Experiment
Rod Jurich
Yeah...as other people suggested
Thanks guys.
In particular, I'd like to know how if the outer screen was to be a pitched one, how I'd do that. A gabled wall essentially.
Monolith wrote:
Thanks guys.
then you will draw a roof over wall...use SEO and hide layer which contain roof
What's SEO sorry?
Monolith wrote:
What's SEO sorry?
SEO = Solid Element operations
You MUST read archicad manual first
search forum for this topics cos ther is planty good tutorials here
http://www.archicadwiki.com/Solid%20Element%20Operations?action=show&redirect=SolidElementOperation
http://www.archicadwiki.com/Creative%20Uses%20of%20Complex%20Profiles?highlight=%28Solid\+Element\+O...
there are more topics on this forum about this...just search it !
