Tom Krowka
Curtain wall
Version 12AC-
What's the best way to put curtain wall inside an existing wall?
Can I get it to show up as a window in the schedule?
Is there a window setup that can be used as a curtain wall?
By curtain wall I mean aluminum storefront frames and glass panels as in a typical strip mall that are punched into a typical wall.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
5 Replies 5
Laura Yanoviak
I would suggest using the Storefront Objects from the AC11 Migration Library -- that's the easiest way to address all of your issues.
Tom Krowka
Thanks, will do it. I wonder why they weren't included on V12.
Tom
[email protected]
www.walshkrowka.com
Laura Yanoviak
Because GS thought that the CW could replace the Storefront Objects -- it cannot. VOTE HERE
Tom Krowka
What happens to the CW question in V13?
[email protected]
www.walshkrowka.com
Laura Yanoviak
The same issue exists in AC13 -- there were some improvements made to the editing interface, but CW elements cannot be considered "interchangeable" with SF Objects -- you still need to punch an empty opening before placing the CW, the doors within CW cannot be scheduled with Door Objects, etc. And I haven't checked, but I would guess that the SF objects are not available from the AC12 Migration Library -- so hold on to those.
