Constructing a 'screen'
I'm having a bit of difficulty in working something out. Basically, I have a facade that extrudes from the main building fabric to form a screen. What I can't work out is how to make this 'wall screen'
I've attached a sketch to show what I mean. Any tips on how to achieve this is much welcomed.
Thanks.
7 Replies 7
Use a wall with a couple of empty openings.
Rod Jurich
Or, 4 walls, or 3 walls, 1 beam, or 3 columns 1 beam.
Or a combination of all 3 elements. How it represents in 2D
will influence your decision. Experiment
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Yeah...as other people suggested
Thanks guys.
In particular, I'd like to know how if the outer screen was to be a pitched one, how I'd do that. A gabled wall essentially.
Monolith wrote:
Thanks guys.
then you will draw a roof over wall...use SEO and hide layer which contain roof
What's SEO sorry?
Monolith wrote:
What's SEO sorry?
SEO = Solid Element operations
You MUST read archicad manual first
search forum for this topics cos ther is planty good tutorials here
http://www.archicadwiki.com/Solid%20Element%20Operations?action=show&redirect=SolidElementOperation
http://www.archicadwiki.com/Creative%20Uses%20of%20Complex%20Profiles?highlight=%28Solid\+Element\+O...
there are more topics on this forum about this...just search it !
