β2004-05-17 08:20 PM
β2004-05-17 08:30 PM
β2004-05-17 09:02 PM
Richard wrote:Thanks for the Tip, Richard. Am doing a pretty high-resolution image and the corners are visible. Truss method might be ok w/ post work in photoshop. For that matter, I could just make my niches of zero depth and just darken them.
Try the Trussmaker tool. (Really!) You can draw lines in elevation pretty much wherever you want, convert to a VERY skinny trussand it looks pretty good in a model, even though the reveals project out, rather than in. You can't really tell.
Of course if you upgrade to 8, you could use SEOs and do it "right".
β2004-05-17 09:16 PM
β2004-05-17 09:38 PM
JasonBarish wrote:Shouldn't be disappointed when using an older version of the software.
Guess I'll have to try to talk my boss into spending the extra $,$$$ to upgrade to 8. Am sort of dissappointed that AC doesn't have a simple method for this... seems like a common modelling operation.
β2004-05-17 11:52 PM
β2004-05-18 12:53 AM
JasonBarish wrote:The upgrade to AC8.1 is a HUGE improvement. It is money very well spent.
β2004-05-18 01:01 AM
β2004-05-20 07:20 PM
β2021-09-23 06:30 PM
I would like to revisit this question. I always used small slabs with SEO to do this, but recently thought that the "opening" tool might work better. It seems to work OK, but I'm having 2 problems: first, in plan they show up in a way that I do not like and it's impossible to turn them off because they are a part of the wall; second, they don't seem to want to wrap around wall corners? I think that maybe just using SEO to create reveals is better. How do other people do this?
