Continuous stair railing on slab
People
Let's say I create a stair from within Stairmaker and add some railing.
This stair ends to a slab that in turn leads to the main entrance door that is at the height of 1.5 m.
How can I add to the slab the same railing that I have on the stair?
The railings that Stairmaker uses are not part of the AC Library.
Thank you in advance
13 Replies 13
Djordje
do you mean that the railings included in "ObjectLibrary9/Building Structures/Fences and Railings" are the same ones Stairmaker makes use of?
Djordje
Djordje
Some of them - parallel bars, etc.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
See also the text files in Add-Ons/StairMaker/Railings
Using these was discussed in the old escribe list ... I haven't tried modifying them or adding new ones myself (yet).
