Converting ArchiCAD 3D Models for AutoCAD Use
I am doing a 3D house model in ArchiCAD. My client uses AutoCAD and wants me to convert my model and send it him as an AutoCAD 3D model so that they can rotate it for various viewing on their system.
Can someone run me through the commands in 9.0 (Macintosh/ArchiCAD preferable) in order to do this?
thanks!
Petros Ioannou
You have to open the 3d window and save as dwg.
If you save a dwg from plan you get 2d drawing of the storey you are on.
When you save from your 3d window then you get a dwg with your 3d model. If i remember corectly faces are triangulated inside AutoCAD.
HTH
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
HTH
Petros
Thanks, Petros. I wish everything were this simple!:0)
Todd
