Converting non-solid morph to solid one
I have a question. I connected two slabs at different levels with an non-solid morph. Is there a way to convert the non-solid morph to a solid one?
David Maudlin
anto_bg:
This is the article about solidifying Morphs: Fix Modeling Errors: Check and Solidify Morphs.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
anto_bg:
David
Thank you, David!
