Copy & Paste and objects remain selected in version 9 ?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2004-10-04
08:09 PM
‎2023-05-23
05:25 PM
Rubia Torres
‎2004-10-04
08:09 PM
13 REPLIES 13
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-10-08 10:14 AM
‎2004-10-08
10:14 AM
Matthew, I'm no expert like you. I have to admit (blushing) that I wasn't aware of this. It's of course a HUGE enhancement to AC7, in which I worked until a couple of weeks ago.
But still. This way I have to remember key combinations, I have to use both hands like in Autocad of old, and I have to remember the right order to click on things to make it work. As an example of the mistakes possible, when i was testing your suggestion, I by mistake started by command-clicking a line. The line of course disappeared, because this is the shortcut for Trim.
If you think about what I described of how Microstation works, you might see what I mean. The dual functionality (verb-noun and noun-verb) lets you click away one-handedly without thinking too much. It just works.
Microstation has many drawbacks, but there are things for Graphisoft too look at, like this detail. Also: great use of multi-threading (on 68K Macs!), several customizable simultaneously active windows/views on the model, and non-modal dialogs wherever possible. 'Nuff said. I wouldn't buy it today, but in the early nineties, they had good programmers.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-10-08 11:11 AM
‎2004-10-08
11:11 AM
kevin wrote:Yes.
My question is, can you have it so the copy is not selected? Some type of override key that keeps the original selected. There are a few cases where this is the preferred method, it would be nice if there were a choice of whether the originasl or the copy is selected.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-10-08 02:14 PM
‎2004-10-08
02:14 PM
Thanks, I saw that too. But that's not what I'm looking for. I like the new method, I just want to be able to override it every once in a while. What I was looking for was something that would let you switch on the fly. A key combination or something that lets you choose whether you want the copy selected or the original each time. Or maybe not that you have to chose each time but a key combination or whatever that lets you override the default.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
massachusetts, usa
Windows 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-10-08 05:25 PM
‎2004-10-08
05:25 PM
Thomas wrote,
The copy command canData CAd uses a similar "verb-noun" methodology. Having both methods available would be ideal. A classic example is that you could choose a distance and direction to copy elements, and each element selected after issuing that command will be copied that distance and direction. This can be useful when selection of the elements to copy is cumbersome to do in a single step.
work noun-verb wise like in Archicad (that is you can select the
subject to be copied first). But they can also work the other
verb-noun way (like i think in Autocad). If you select the command
without any object selected, it allows you to select the object to
copy after the command
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
