Copy objects between stories
Can you copy window and door objects between stories without copying the wall at the same time? I have two floors where the walls are similar, and would like to copy the windows/doors that are in the first floor to the blank walls in the second floor.
I've tried to drag a copy in the 3d and elevation views as well as use the stories settings and cut and paste, but I have not succeeded.
Thanks,
Jason
3 Replies 3
Steve Jepson
no. for the same reason you can't draw a door or window with out a wall. You can use the eyedropper/syringe thing. I think it's called the Transfer Elements' Settings Tool.
to speed things up a wee bit copy the parent wall to the storey you're working on (off to one side) and syringe your doors and windows
bill
sorry, i meant eyedropper
