AGaspar
Copying Walls between stories problem.
I´m having a problem copying walls between levels. When I copy and paste a wall on to new level the paste walls becomes 2d (Lines and Fills).
I can copy past on the same level with no problems or in between diferente Archicad projects, but not in the same file.
This is happening only on custom composite walls I created personally. If I use a composite wall that came with Archicad it works fine.
I´m Working on Archicad 25.
10 Replies 10
tajlbrown
Beginner
Hello,
I am having the same issue mentioned in the initial post of this thread. When I copy a plan, to another level, the walls show up as lines and fills instead of walls. I am not using any special wall types or have any plug-ins that I am aware of that will cause this. Any help is greatly appreciated.
Thank you
