Copying from many storys at the same time?
Hi. I have a house that has 4 storys.
I want to copy all 4 of the storys and add them to the other 2 parts of the house.
How do I do it without copying each story separately?
I have only worked with archicad for about 2 weeks, so Im a bit lost.
7 Replies 7
TomWaltz
You can use the All-Story marquee to select the wing, then use Copy/Paste to place a copy of the wing. You need to rotate the copy BEFORE you click outside its "paste-marquee".
Tom Waltz
Dwight
and the all story marquee is here:
----- this can also be done in 3D:
first GROUP the elements to be copied on each floor plan, select them in a 3D view and drag a copy.....
Dwight Atkinson
Cheers!
Djordje
In your case, marqueeing and Multiply/Rotate with 2 copies and Distribute -1 should do the trick nicely.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Dwight
You have more confidence in that marquee than I do.
Dwight Atkinson
Aussie John
dont forget you can make modules to place in the other areas if they are to be identical. ie update one wing - all wings update.
Cheers John
[/size]
Djordje
Been there, done that.
Djordje
HP Omen
