2004-02-17 09:07 PM
2004-02-17 09:33 PM
Archimac wrote:Corner boards are most easily done IMHO with tiny thin walls - because you can trim them to the roof. Use an intersection priority number that is unique, so they do not clean up to the adjacent exterior walls. Their fill should be solid so that they stand out against the horizontal fill of the adjacent siding. If you don't have a belly band/etc and want the corner board to cover multiple floors, just make it a really tall wall on a single floor unless you want them to show up on all floor plans. (You can move and stretch the corner-board wall in the 3D window to get the correct base and height.) I only show them on elevations and exterior renderings (and so have them in a layer that ony shows up in those combos) and call them out on the elevation.
I am wondering how to attach wood corner trim to houses with wood siding. I want them to show up in the elevations automatically. Also, what about brick quoins a the corners. Any traditional residential master out there?
2004-02-17 11:46 PM
2004-02-17 11:50 PM
2004-02-18 12:46 AM
2004-02-18 01:59 AM
Archimac wrote:Glad I could help. If I understand what you're asking, no, I don't know of any good tutorials for doing residential architecture per se in AC. IMHO it is simply a matter of knowing how to build (and design). In ArchiCAD, you model the way the structure is to be built and the drawings (generally) take care of themselves. The part one needs to learn is how to set up office standards (layer combinations, materials, fills, etc.) and to use the tools effectively ... which includes realizing that no tool is only for what its name implies but rather for the type of geometry it generates, with the exception of the wall tool since walls are the only objects into which one can place windows and doors. OK roofs are the only objects into which one can place skylights. But, for example, the roof tool would be used to draw a sloped ramp or driveway as well.
Great info Karl!
At least I know there is a possible way to do it. Do you know where I can find good tutorials on traditional architecture (residential) using Archicad. Or maybe good add-ons etc.? I am currently playing with the demo which is a simple building but far from reality. I would want to know that Archicad can do all these things before I bought it for sure.
2004-02-18 02:04 AM
Rashid wrote:Absolutely. Open the 8.1 library PLA and choose the option to save it into a folder on your disk. Close AC.
I am 2 months into AC and.. wonder if there is a way to weed out library items i absolutely will never use...
2004-02-18 04:04 PM
2004-02-18 06:50 PM
Archimac wrote:Used to be there in the standard library ... id not need it for two years or so, so did not check recently.
2004-02-18 07:16 PM
