Corner window
NandoMogollon
HI,
does anyone knows how to make a corner window without frame in the corner???
i need the corner in a "glass to glass" join type
i really can't find how to do it.....
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
6 REPLIES 6
TomWaltz
I knew I had seen this somewhere recently, but took me a minute to remember where....
From tr.graphisoftus.com:
"Try the "W Fixed 10". To achieve a non-corner frame you have to do the following:
1. Place this window as a corner window
2. After placing select the window from the plan and set the parameters of the “Corner Window Function” as in ScreenShot
NOTE: the No Frame at the Corner option is “inside” the Corner Window Function On parameter group."
Tom Waltz
NandoMogollon
sounds good,
but i can´t see the SCREENSHOT-1.....
Can you send it again?
Nando Mogollon
TomWaltz
sorry, there was not one that I posted... though you could follow the link and find it.
Tom Waltz
NandoMogollon
thanks Tom.
The link didn't work the first time.... now it does.
thanks a lot....
Nando
Nando Mogollon
Srinivas
Is it there in the Internation Version ? But I couldn't find it. Can someone post the "gsm" for me.
Thanks in advance.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
NandoMogollon
Thanks in advance.
I couldn`t find it neither....
i`ll ask again, Maybe someone can post it.
Nando
Nando Mogollon
