Corner windows
I can't find the corner window tool. Is this an add on? Or is it somewhere hidden in another tooldialog?
rocorona
It CAN be hidden, but in the same ToolPalette. Did you open all the sections? If it is not there, then it can be "more hidden".
Look at the Options>Work Environment command. Browse to the Tool Bar section and check. If you need help on this command settings have a glance to the ArchiCAD Help, in the Help menu.
BTW, it is ALSO an add-on, but I dubt this can be the problem.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Found it under "more". Thank you for help. Now i need to work with it a bit to find out how it works...
