‎2016-08-2606:50 PM - last edited on ‎2023-05-2412:41 PM by Rubia Torres
‎2016-08-2606:50 PM
The Help Center explains how to Create Complex Profile from Parallel Elements by using the Edit > Reshape > Merge Walls/Columns/Beams. But the Reshape command does not show anything that says Merge Walls/Columns/Beams.
Are you using a custom work environment?
If so maybe those commands aren't in your menu structure.
Try the standard work environment or add them to your custom one.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
