Create DWG from 3D ArchiCAD
Hi.
Is there a way to take a 3D view in to AutoCAD as a DWG?
I am hoping to take some line drawings of my perspectives and axonometric in to AutoCAD to further edit.
Obviously it will be flat right?
Thanks.
17 REPLIES 17
Dave Jochum
ejrolon wrote:
Just did a Save-As from the 3D window and it works.
OK--this is weird. I can't figure out what settings I have different than you. I've tried three times and only get a plan view dwg.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.6.1•AC 29 Silicon (latest build)
Eduardo Rolon
You are opening the 3D Window and doing a save as from there?
Not publishing or saving from the floor plan?
If you open the file in Autocad(if you have it) or in Draftsight (if you do not) take in consideration that it will display the model in "top view" and in wireframe.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Dave Jochum
Bingo--thank you. I use SolidWorks eDrawings to view and didn't realize that it was displaying the 3D model in plan view. So now I realize that even though I can get a dwg of a 3D MODEL, there is no way to match the exact VIEW from the AC 3D window. I also can only get a parallel projection, as the perspective option is greyed out, but maybe that's a limitation of the viewer I'm using.
Dave Jochum
Yes. It's just the viewer. I don't know any way to export the camera viewpoint though. You could place a marker (an arrow shaped slab or such) and the artist may be able to set up a view from there base on your perspective settings. Since none of us know his process it's hard to speculate.
Dave Jochum
Thanks, Matthew. I was thinking I was exporting to a 2D DWG file of the camera view. Seems odd to me that is not available. Even I don't understand his process using the 3D DWG file, but I am giving him an EPX file, as I want the base work done in Piranesi.
Dave Jochum
For a DWG of the 3D view you should be able to save that from a 3D document window.
Dave Jochum
Yes, but there seems to be no control over the size of the resulting image--no?
Dave Jochum
I just checked and the 3D Document saves DWG to world dimensions at 1:1 scale. You can reset the scale to match the output size.
