2006-01-18 03:11 AM
2006-01-18 04:57 AM
archcom wrote:Find the Cutplane command.
I Want Create floor plan show in 3D (Shader/Render)...Help me Please.
Thank.
2006-01-18 06:22 AM
2006-01-18 08:15 AM
2006-03-09 04:26 AM
There is a similar trick where the floor plan is:I was able to insert the floorplan which I converted into an ArchiCAD Library object (.gsm) and re-insert it, where it is visible in the 3D view. The floorplan consists of lines, hatches and text. However, some problems surfaced: -
saved as a DXF,
then opened as a GDL Object,
saved into the ArchiCAD Library,
then placed in the floor plan view as an object.
The resultant lines will be visible in a 3D view and renderings.
2006-03-09 04:29 AM
2006-03-09 04:35 AM
2006-03-09 05:23 AM
2006-03-09 05:40 AM
2006-03-09 07:12 AM
