Create an Arched Cornice using profilemaker?
I want to create a 6" tall x 3" deep cornice over an arched opening in a wall. Help!
13 REPLIES 13
Design>Complex Profile>Profile Manager> select NEW.
A drawing window will open.
Draw a profile (a section cut view) of what you want.
Pay attention to the fills you are using.
In C.P.s, it's all about the fills and their edges.
Any lines you draw are only guides, they don't show.
You will then extrude (stretch) that C.P. out on your plan.
Takes a bit of practice but you'll get it.
Hope that helps a bit.
lec
Ralph Wessel
Mentor
Do you want something curved with the arch like the attached image?
Ralph Wessel BArch
Active Thread Ltd
Jorge Cortes
I'am not the person how makes the question, but I have the same problem, and yes, I want something like your attached image, How can I do it?
I was trying with complex profile, but I can't make a vertical arc.
Thanks,
Arq. Jorge Cortés M.D.A.
You're right,
You can't make it vertical, but you can rotate it saving it as an object
Ralph Wessel
Mentor
Do the free trial with OBJECTiVE to see if it suits your requirements. I made the arch by doing the following (referring to the attached image):
  • 1. Open an elevation view of the wall where the arch is to be placed. Draw the cross-section of the arch profile with a fill and create a section profiled object with OBJECTiVE > Component > New Profile.
    2. Place one of the new profile objects across the arch.
    3. Use OBJECTiVE > Tools > Bend to shape the profile to the arch
    4. Use the profile setting to extend the start of the arch (for the straight vertical section)
    5. Use OBJECTiVE > Tools > Split to cut the apex of the arch
    6. The finished result.
Ralph Wessel BArch
Active Thread Ltd
griggadee
Are there any other methods for creating this, without using the cadimage plug-in?
Essentially, I just want to create a custom profile that I can curve vertically to create a curved architrave at the head of a window.
Cheers folks...
Paul Griggs BSc (Hons) MCIAT MCIOB
Chartered Architectural Technologist
AC23, i5 3570K Processor, 16gb RAM, NVidia 570GTX Graphics Card, 250gb SSD Drive
runxel
Hero
You could try it with morphs – with some prework it should be quite easy, I think.
griggadee
I don't see how I can extrude a custom profile vertically to form a curve. I am not clued up on using morphs. Any example videos you can recommend?
Try Eric Bobrow's video here: https://www.youtube.com/watch?v=_EGdK-D7zXY
Richard
AC26 (since AC6.0), Win10
