‎2003-10-30
08:27 PM
‎2023-05-23
05:31 PM
Rubia Torres
‎2003-10-30 08:39 PM
Luc_M wrote:It depends on what version of ArchiCAD you are using. It's a little different from ArchiCAD 7.0 to ArchiCAD 8..
I'm still not familiar with creating library parts, doors, windows, etc. in AC 8.
I've drawn my new door lying down with slabs, and now I'm looking at it in my 3D window from a parallel side view at 90 degrees... How do I save that as my door? Is it a GDL object?
‎2003-10-31 07:57 PM
‎2003-10-31 11:22 PM
‎2003-11-01 06:08 AM
‎2003-11-01 09:02 AM
‎2003-11-01 09:56 AM
Luc_M wrote:Whatever objects you create by slabbing and walling, it is adisvable to do it on the origin. Start form the obviously logical insertion point as the origin.
Thanks Ben!
Works like a charm!
The only thing I noticed a bit different, is that your window absolutely has to be at 0,0,0 when you do your 3D view before you save, otherwise, the windows are waaaaay outside the wall =O)
Thanks again!
Luc
‎2003-11-01 09:57 AM
Thomas wrote:Agreed; David forgot the status codes I think.
Djordje,
this one should be in the Archiguide (if it isn't already)
Thomas
‎2003-11-01 10:10 AM
‎2003-11-01 03:29 PM
Ben wrote:Now it is at http://archicad-talk.graphisoft.com/viewtopic.php?t=211
Great tutorial David.Thanks for sharing it with us...
