2017-03-28 03:45 AM - last edited on 2023-05-24 08:32 AM by Rubia Torres
2017-03-28 04:29 AM
2017-03-28 11:43 AM
2017-03-29 10:17 PM
Barry wrote:A minor point - I wouldn't use "upward extrusion" as the overhanging scroll and the small triangular projection will extrude upwards also. Just make sure the morph is at least as big as the wall you want to subtract from, and use the straight out "subtract" option.
Stretch the wall height so it is slightly higher than the detail.
Place the morph in the desired location and ensure id extrudes across the wall.
Then Solid Element Operation and subtract with upward extrusion from the wall.
Hide the morph by placing it in a hidden layer.
2017-03-29 10:41 PM
2017-03-30 08:23 PM
