‎2010-09-23
07:20 PM
‎2023-05-23
04:47 PM
Rubia Torres
‎2010-09-23 10:57 PM
‎2010-09-24 10:14 AM
marcusk wrote:Hi Marcus,
how can i create an object (in this case, a triangle) using three different points in a 3-dimensional coordinate system?
‎2010-09-24 11:06 AM
qwsoftdraw wrote:I actually have made a slab, then turned it into a GDL object. But the new object never fits perfectly into the hole. Is there a way to strech the objects corners to different points in 3D coordinate system? Without it resizing the hole object, that is.
Make the shape of your object using a slab, save it as a GDL object, then open the GDL object to edit it.
‎2010-09-24 12:53 PM
‎2010-09-24 01:17 PM
‎2010-09-24 01:27 PM
‎2010-09-24 02:48 PM
marcusk wrote:marcusk:
I now filled that triangle shaped hole, next up is a square hole. Hopefully it works the same way.
