β2004-03-01
09:06 PM
β2023-05-23
05:29 PM
Rubia Torres
β2004-03-01 09:30 PM
β2004-03-01 09:33 PM
β2004-03-02 09:37 AM
β2004-03-02 09:38 AM
β2004-03-02 09:45 AM
chris_pap wrote:NO! Never go back!
I would hate to go back to AutoCAD for such a simple matter..
β2004-03-02 10:00 AM
β2004-03-02 10:04 AM
β2004-03-02 10:16 AM
chris_pap wrote:Awful, if you use the "save as GDL method" I just posted. You'll hate it.
By the way,how will this look on the floor plan?
Chris
β2004-03-02 12:30 PM
chris_pap wrote:Easy: Use slabs for steel sections. Set the thickness and draw your plan dimensions. There are pipes in the library if you need them. Build it up from the ground, adjusting you heights as you go. Check it in the 3d window or, better still, build it entirely in the 3d window.
...I am not sure how can I build railings using slabs walls and roofs.Chris
