Creating double curved walls in AC
Is it possible to create double curved walls in ArchiCad? I am trying to create a building shaped somewhat like an egg... But unfortunately I am not skilled enough to create this kind om geometry... Can anyone help me?
I am also wondering if it is possible to change the section height of plans. An example; I have made some columns with a special top. My problem is that I don`t want them to be visible at the plan. Only in sections and 3D.
Thank you
5 REPLIES 5
"Double cureve" walls unfortunately not...
but You can use the addons like Archiforma which might help...
As for the other question - use the layer combinations or saved views or both...
Best Regards,
Piotr
As Piotr suggested, ArchiForma can create these shapes ... or you can create them visually with the mesh tool, then save as an object to get them rotated into the correct configuration, or if it is a perfect elipsoid, you can use an object in the Special Construction / Basic Shapes library folder. You can also create the geometry in an external program and import it as a library part (3ds, dwg, etc.)
But, no matter which method you use, the result will not be an ArchiCAD "wall" in that you cannot insert windows/doors and openings in it. Rather, you will have to cut your own openings with solid element operations.
As Piotr says: layers and layer combinations.
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Djordje
Not necessarily; ArchiWall is pretty smart. It is not a wall, but it reads the openings from the template one, and does double curve.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thank you!
Unfortunately I am a student, and don`t have access to these plug-ins (ArchiForma and ArchiWall), so I guess I will have to try to make it with the mesh tool...
Djordje
tenkje wrote:
Thank you!
Hmmm ... maybe a good soul that has the full license near you might help?
Don't know what is Cigraph's policy re the EDU versions, maybe Fabrizio might say?
Djordje
HP Omen
