Creating floorplans with shadows
I am trying to create a floor plan with shadows on it. I saved the shadows in .2dl format, but it contains a lot of errors especially arround the stairs.
Is there any other way to add shadows to a floor plan?
thanks
3 Replies 3
You can copy/paste from 3D to plan. Are the errors in saving the file or the shadow generation? If the latter, the only fix is probably to clean it up manually.
I tried copy/paste but the errors remained. So it must be the shadow generator. Is this normal?
I also tried to change the 3d engine but the opengl doesnt create shadows.
Shadow generation has always been a little flaky, though it's gotten better since it was first introduced. Since you mention stairs, the problem may be with the shadow generation actually being turned off for complex elements (ie small polygons).
Do you have high accuracy turned on in the Photorendering Settings? I am not sure, but I suspect that this will also influence the vector shadows.
Shadow casting can also be turned off within the GDL script of library parts themselves. Check for a user parameter to adjust this. If shadows are turned off inside the script (without a user parameter) then the only fix is to edit the script.
