ā2021-09-11 05:04 PM
Hi, i always encounter this problem in the design process,
making wall recess don't always give a clean result in floor plan, i used several methods, using niches, column / beams with a higher material priority,
in this exemple i used a column,
is there a solution for that ?
Thanks
ā2021-09-12 07:18 AM
Hi, do send 3D view of this wall n door area. Any plaster surface you are willing to show on as outer skin of wall?
ā2021-09-12 09:53 AM
Yes i'll need to add a thin plaster skin later
ā2021-09-12 11:10 AM
Here is Ć sketch, iām not in office tokay
ā2021-09-12 02:07 PM
try this Option-1 :
Option-2 : Define new door with two unique ID's Wallhole & Wallniche.
ā2021-09-13 03:29 AM
Rather than SoE-ing, could you instead us a Wall Niche?
