Cross Referencing Details In PM 3.1
Hey everyone.
I did wall section in AC and placed few details that i would like to detail even further.
Know i inserted wall section in PM and details that i have done. how can i reference these details to the page where wall section is located. wall section automatically references.
Thanks
Ben Odonnell
Have you used the detail tool? If so when your import you ArchiCAD pln you will be able to import your details as well. This is the best way.
If not, you can copy your existing wall elevation, as many times as you like whilst in Plotmaker, then while you have your drawing marked you can move the contents of the selected window around, until you see the next part of the drawing that you want to show.
Although this is definitely NOT the best method.
You should try to use the detail tool in ArchiCAD.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobjectĀ®
Thanks Ben
Thats what I tought
i was thinking that there is way to do this by using title types
Ben Odonnell
dmoraca,
If you do it the right way and use the detail tool in ArchiCAD, your title types will reflect the drawing name/number.
HTH.
Ben
Ben O'Donnell
