Cumulative distance
I have a problem with the measure-tool. Can anyone help me?
The problem: when I measure a perimeter in a section, (so I look what the cumulative distance is,) is it important that your view of plan is set on the ground floor. If it stands on the second floor (f.i.) the cumulative distance adds the height of the second floor with the measurement!
Is this a bug in the system or just a change in the settings?
Thanks!
1 Reply 1
I have noticed it before but I just tested it, you are right.. I'll look for a solution!
