Curtain Wall: Independant Scheme Removal
Lingwisyer
Guru
Hi All,
I have a portion of a Curtain Wall in AC22 that appears to be independant of the rest of the scheme and I am unable to remove it... It is also preventing me from extending the left edge of the main scheme beyond where the two meet...
Ling.
4 REPLIES 4
ryejuan
can't you just delete it?
In the end what is your Objective?
ArchiCAD 9 onwards
Nothing happens when I try to delete it... I am also unable to move the boundary between the two...
its not locked globally or locked within the layer right? have you tried isolating it in 3d and modifying from there?
ArchiCAD 9 onwards
Lingwisyer
Guru
I can edit everything else about it in both 2D and 3D. So there is no issue there.
