Curtain Wall and Timber Frame construction
I'm creating a timber frame building, of which will have curtain wall. How can I do it so that when I create a window the columns that make the wall joists cut to the window as the window is complex ( in terms of shape ). I've tried the SEO but no matter how I set it up, the columns just don't cut.
Thank You
23 Replies 23
Ralph Wessel
NStocks wrote:
I would really like to show the structure ( timber construction ), however in 3D with the windows only
Try modelling the timber framing with OBJECTiVE - it comes with a full compliment of timber and steel objects, and the timber objects can show a single/double line when cut in cross-section. You can place timber objects directly into your elevation views too, cutting and rotating as required (see an example here). You've used OBJECTiVE for modelling other objects so you should have it installed and be somewhat familiar with its tools.
Ralph Wessel BArch
Central Innovation
What would happen if I placed a custom window in plan ? Would the timber frame cut, just as a wall would ?
Thank You
Ralph Wessel
No - ArchiCAD only allows windows to be placed in walls unfortunately. If you want windows to appear in an object model, I would place them within a wall just big enough to bound the window so the window appears to be independent. Then you can place it wherever you like.
Ralph Wessel BArch
Central Innovation
Structural members are never cut by doors or windows. An occasional hole for pipes or wiring is OK but otherwise the structure is inviolable. If you use the wall tool for partitions and sheer panels (exterior skins) then doors and windows can be easily placed in these.
