Curtain Wall in Section
I have a vertically butt glazed curtain wall. I have not been able to get the Horizontial Mullions to show in section. All I see is the solid area where the mullion should be if it passed thru or intersected the glass. I have tried all of the control settings. Any ideas?
__archiben
try this ---->
failing that, can you post a screenshot?
(also - make sure that you don't have two overlapping objects: their contours can sometimes cancel each other out . . .)
~/archiben
b e n _ f r o s t
I am having problems getting the top and bottom Horizontial Mullion to show at the proper length and width. It shows as a square instead of showing 1.5x5.5" like the other horizontal mullions. I have not figured out how to send a section.
