Curtain Wall question
So this is probably a simple problem. I'm making a curtain wall which I would basically like to be floor to ceiling glass with no intermediate horizontals. When defining the scheme in the curtain wall settings it looks like this will be the case. But when I make the wall, it has this transom along the top which I don't want (image). Any help would be greatly appreciated, thanks
4 REPLIES 4
Post an image of the Scheme Settings of the Curtain Wall.
Probably the vertical size of the panels is not large enough.
Here are the scheme settings. Thanks
So your vertical size of your panel is 2700.
Make it at least the same amount as the height of the Curtain Wall.
Ah yep, like I thought, simple problem. Thanks!
