felcunha
Curtain wall bug
Hello all,
It seems there's a bug with curtain walls in AC22.
After inserting a new node on a segment, one of the two new segments become automatically "custom".
Try the following :
Draw a single-segment curtain wall;
Insert a new node on it (the segment can remain straight as a single line or not); Change its width.
You'll see that while one of the segments will change, the other remains as before...
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Emil Meijer
Graphisoft Alumni
Graphisoft Alumni
While this may seem like a bug, it's actually a feature.
Just like you mentioned, whenever a node is added to a curtain wall, the icon will appear in the Scheme section. After pressing the "Reset Custom Segments" button, you need to type in the width one more time, and then both segments will be given the same attributes.
